My new 360
Re: My new 360
Ignore Foggy, Rupert is correct here, you need twin SU's it's simple. Just because it's a project car doesn't mean it should drive like a dog ;) Granted Webers will give you more if you really want to tune the hell out of it, but do you?
She does look good though mate!
Re: My new 360
How did I know that Chris would be along ;) Tune either sort of carb wrong, and the car will be a dog...there's nothing wrong with either design...except that the SUs don't flow as well.
I know where there's a K if you can find someone who'll weld the rear thrust bearing ring back onto it ;) I could attach it, but no promises can be made about the resulting engineering tolerances :D
The slow-down at the top end will almost certainly be the undersized carb. The engine is being choked once the airflow demands increase. Put a pair of them on and that should get much better. Of course put a pair of Webers on and it'll get better still...;)
Re: My new 360
Haha.. this old debate... ;) I'm reluctant to bother with twin SU's as it'll involve a custom manifold, which will easily exceed buying a Weber bolt pattern manifold off the shelf. For an inferior performance upgrade item I don't really see it being worth the effort.
I did suspect it'd be the carb (and I'd assume the standard cam) holding it back... on paper it should be quite good engine wise though, I gather the 405 head flows marginally better than the 531 as I think it has larger valves?
Re: My new 360
Post by trabitom99 »
SteveP wrote:As for a drop, probably not as I'm happy with it looking grandad spec :D I dunno, the suspension does need something doing to it... but I'll probably just go for gas shocks, stiffer front springs and maybe an upgrade to glt rear leafs.
Any new suspension parts will improve the handling by 1000%, no need to lower it ... It's not a Mk1 ;-)
I'll be interested to see what you're doing performance-wise though, as I suspect my DLS will have the same carb/engine/cam setup?
Re: My new 360
trabitom99 wrote:Any new suspension parts will improve the handling by 1000%, no need to lower it ... It's not a Mk1 ;-)
I think I agree... the ride height isn't bad for a 'stock' looking car, and I kinda want it to look fairly standard anyway.
Yep pretty sure your DLS will be identical Tom. I need to find out what cam it has actually, but whatever it is its certainly not designed for enthusiastic driving!
Re: My new 360
Unfortunately, I have no idea how my DLS drives anyway, as I've only ever driven it about 10 metres in 7 months :-(
This thread needs another pic:
I loved that chrome tow bar cap :-) Still reckon the chrome trim rings would have suited your car perfectly, although the leos look great on it too of course ...
Re: My new 360
Poor thing... DLS daily driver while the current daily gets fixed up? ;)
I have to admit I'm not a huge fan of the chrome, hence the Leo's and Hella grille - but I think it's alright now, I quite like the rest of the chrome guttering/bumper capping etc :) The tow bar cover is pretty hilarious though, wonder if it's original :lol: Perhaps? The towbar is a geniune Volvo towbar (which is actually a bit of an abomination!)
Re: My new 360
SteveP wrote:Poor thing... DLS daily driver while the current daily gets fixed up? ;)
Unfortunately not, the DLS has no MOT and dodgy brakes, whereas the daily is "only" rusty ...
SteveP wrote:I have to admit I'm not a huge fan of the chrome, hence the Leo's and Hella grille - but I think it's alright now, I quite like the rest of the chrome guttering/bumper capping etc :) The tow bar cover is pretty hilarious though, wonder if it's original :lol: Perhaps? The towbar is a geniune Volvo towbar (which is actually a bit of an abomination!)
That tow bar cover may well be original, Mk1s certainly had them ...
Having recently fitted one I think they're great, and wish I'd got around to it sooner :-) You need to remember them when you're parking though :oops:
Re: My new 360
The reason I love SU/Stroms is the near idle throttle response, they just don't have the flat spots that fixed chokes have ;) Tbf, I had no idea that both the B14 and the B172 had such flat spots until I was forced to drive a car on SU's but it really makes a hell of a difference.
Sensible option is of course to bin all of it and run FI. The last week has seen some minor tweakage to Fakes ECU which has done wonders for flat spots and my idle :D
Re: My new 360
Well... it now has its first problem :roll: :lol:
Mainly that the carb is buggered... leaving me stranded about a mile away from my destination with what felt like about 10bhp (Not much chance of getting up ANY gradient!). Initially it started idling low about 3 weeks ago at Griz's meet, then recently would stall when warm... but then the symptoms seemed to go away... until last Sunday! Then pretty suddenly the car was severely lacking in power, but no misfiring or stuttering - just no real difference in power between tickling the throttle and with the throttle wide open. Called the AA out in the end and diagnosis is the piston in the carb is sticking - when provoked the car revs up as normal. I actually reckon it's been doing this almost since I've had it because it seemed to rev way more freely when provoked and I'd always complained about its reluctance to rev beyond 4k. Luckily L14AM is coming to the rescue with a spare Stromberg CD175 which I can hopefully just swap out and keep the spare one for a rebuild on the bench. So i would therefore like to conclude... Stromberg's for the lose :P :lol:
Fingers crossed the carb will arrive and I can find a dry day before Sept 11th!!!
Re: My new 360
Weak Carbs suck. :(
Re: My new 360
Webers. You know it makes sense ;)
Stupid question...you have been keeping the damper fluid level topped up, right?
J340GLT
Re: My new 360
Post by J340GLT »
whose is the s60?
Re: My new 360
foggyjames wrote:Webers. You know it makes sense ;)
There is that... but I'm not so sure it's worth it - I've hardly used the car this year :? :( And yeah I topped it up not long after I got it back from yours so it's rather annoying!
Re: My new 360
The damper fluid doesn't lubricate the piston, it provides a damping force against it.
How long have I told you to get on and do a rebuild on that carb :P :lol:
