B19 VS B200
TheNed
Re: B19 VS B200
Post by TheNed »
That's for your fuel pump and stuff. Did the carb model run a electric fuel pump?
'86 360GLT
I bought a volvo and I liked it.
mrborrie
Re: B19 VS B200
Post by mrborrie »
Not sure still got that in storage, i did however took the pump of the partscar so i should be able to work that out
764 Turbo 86'|Volvo 144 72|Volvo 360 86'||Volvo 360 GLS 85'|242 77"|
Website: http://www.brick-autosport.com
Facebook: http://www.facebook.com/pages/Brick-Aut ... 98?sk=wall"
alf
Re: B19 VS B200
Post by alf »
Quick question: On a b200 e block, can i swap the head from a b19a? I'm worried about how the timing wheels will ne aligned or not. Ps: The car is from 86, and the head drom b19 is from 84. Many thanks.
the early bird gets the worm
Joris
Re: B19 VS B200
Post by Joris »
alf wrote:Quick question: On a b200 e block, can i swap the head from a b19a? I'm worried about how the timing wheels will ne aligned or not. Ps: The car is from 86, and the head drom b19 is from 84. Many thanks.
Heads should be interchangeble. Not sure if there are pre-drilled holes in the b19a head for the sensors.
alf
Re: B19 VS B200
Post by alf »
I'll check that out,thank you. I'm not sure if i have a burnt valve,and The thing is i need The car running. Now i need your advice: Shall i overhaull my head(b200) with new valves,guides and seats, or shall i repair a b19 head from previous car?
