Page 2 of 2
Re: B19 VS B200
Posted: 16 Mar 2011 09:01 am
by TheNed
That's for your fuel pump and stuff. Did the carb model run a electric fuel pump?
Re: B19 VS B200
Posted: 18 Mar 2011 04:55 pm
by mrborrie
Not sure still got that in storage, i did however took the pump of the partscar so i should be able to work that out
Re: B19 VS B200
Posted: 08 Sep 2014 05:58 pm
by alf
Quick question: On a b200 e block, can i swap the head from a b19a? I'm worried about how the timing wheels will ne aligned or not. Ps: The car is from 86, and the head drom b19 is from 84. Many thanks.
Re: B19 VS B200
Posted: 08 Sep 2014 06:42 pm
by Joris
alf wrote:Quick question: On a b200 e block, can i swap the head from a b19a? I'm worried about how the timing wheels will ne aligned or not. Ps: The car is from 86, and the head drom b19 is from 84. Many thanks.
Heads should be interchangeble. Not sure if there are pre-drilled holes in the b19a head for the sensors.
Re: B19 VS B200
Posted: 08 Sep 2014 08:08 pm
by alf
I'll check that out,thank you. I'm not sure if i have a burnt valve,and The thing is i need The car running. Now i need your advice: Shall i overhaull my head(b200) with new valves,guides and seats, or shall i repair a b19 head from previous car?
