ok i need a colour code for a red 360 glt
ty360volvo
Post by ty360volvo »
ok so i need a colour code for a red 360 GLT 1984
dose any one know it or know where to find it?
please i need to know asap so i can get my dad to pic it up tommorrow morning :360:
whiskeyonesix
Re: ok i need a colour code for a red 360 glt
Post by whiskeyonesix »
Look on the plate on the bonnet panel just above the Rad, This should have the plate code and vin number on it.... or I think so...
Or you could just ask the paint stockist for a litre of Volvo Sun-bleach Red - I guarentee it'll match perfect :)
For proof of this, compare your car in your avatar and my car in my avatar - they're the same colour - but you wouldn't know it :lol:
Mods: custom paint fade
New Cylinder head.
Auxilary cooling fan.
Vario Vents FTW
G8 4 DRFTN etc....
ty360volvo
ok well had a look but still not shore it said a few diffrent codes
like
46
155-5
6324
dose any one know what they are?
whiskeyonesix
46 rings a bell. Think i've seen it on here before now... Pretty sure thats it!
New Cylinder head.
Vario Vents FTW
G8 4 DRFTN etc....
2 Fast 4 U
Post by 2 Fast 4 U »
Volvo Car Paint Codes
The paint color code identifies the original paint color of the body. The code is found on the vehicle identification plate usually located under the bonnet. The same color code was used on different Volvo models. For example the dark blue code 96 was used on the Volvo 120 and 140 Series. Of course both are exactly the same color. Also note that particular color codes may have more than one color name for marketing purposes.
Some cars will have -1, -2 or -3 in the paint code, such as 100-1. The -1, -2, -3 refer to a different shade of the color. -1 being a lighter shade and -3 being a darker shade.
Volvo originally used a 140° Enamel paint, mostly Glasurit or Herbert’s.
For the repair-market there was an 80° Enamel air-drying paint available.
Volvo's paint codes were changed from December 1988. Both solvent and water based paints are now used on cars. In order to easily identity extra digits have been introduced which indicate if the paint is solvent or water based or has another quality
Example: 850 has the paint code 189-21. The first three digits (189 in this case) is for Volvo's color code 189 Polar White
The fourth digit stands for:
1 = BASF (Glasurit)
2 = Herbert’s (STANDOX)
3 = Becker’s
4 = IDAC/DuPont
5 = Sickens
6, 7, and 9 = not used
8 = IVI
The fifth digit stands for:
1 = solvent based
2 = water based Metallic/Pearl + Varnish
3 = water based Solid + Varnish
4 = solvent based Solid + Varnish
5 = solvent based Pearl shine + Varnish*
6 = water based Solid/Metallic/Pearl + 2 component Varnish
7 = water based Solid/Metallic/Pearl + powder Varnish
8, 9 = not used
*Because of the transparent pearl coat this concept includes a solid color which is applied under the pearl coat
Code Color Used on
19 Black Stone 340 360
155 Signal Red 340
183 Blue Grey metallic 340 360
184 Silver Grey metallic 340 360
186 Dark Red metallic 340 360
187 Anthracite metallic 340 360
195 Blue Gray 340
198 Wine Red 340
199 White 340 360
206 Dark Beige 340
207 Dark Blue 340
208 Dark Green / Onyx metallic 340 360
209 Light Beige metallic 340 360
217 Red 340 360
218 Arctic Blue metallic 340 360
219 Ocean Blue metallic / Blue Gray metallic 340 360
220 Gold metallic 340 360
221 Red metallic 340 360
226 Light Green 340
227 Slate Blue 340 360
228 Dark Gray 340 360
231 Bright Red 340 360
232 Scarab / Petrol Blue 340 360
304 Graphite Gray metallic 340 360
305 Black metallic 340 360
306 Smoke Silver metallic 340 360
308 Beige metallic 340 360
312 Peppermint metallic 340 360
313 Champagne Gold metallic 340 360
ty360volvo
WOW you know your stuff
when you said 155 siren red 340 was that not on the 360?
2 Fast 4 U
That I don't know, it's possible that colors were used on different models in other countries
whiskeyonesix
What you could do if you wanted to be certain, is to give your local Volvo dealer a call, and quote your VIN number to the parts dept there. Depending on how friendly they are, they might be able to tell you. Signal Red 155 seems about right to me.
New Cylinder head.
Vario Vents FTW
G8 4 DRFTN etc....
Post by trabitom99 »
That's definitely Signal Red 155. I've got two of 'em :-) I didn't know colours were restricted to certain models before, unlike interior trim. If so, there'll probably be differences from market to market, we certainly got red (155) MkII GLTs over here ...
