Painting advice
Painting advice
After my amateur weldings last year I kinda ran out of paint in the final stages. And then it got icy, and then it snowed and then it was christmas...
The result being that I've already got surface rust. Which is ok, we all need to learn sometime. This time I want to make sure I do it properly. Taking the welds all down flat (some have 0.5mm left sticking out), sanding off the paint. Then apply some underseal to the sills and paint over again in good weather.
So I need advice, can I rely on simply warm weather and heat guns to stop it rusting again? How many coats should I go for? And finally how warm should the metal be?
Re: Painting advice
Post by filthyjohn »
Steel loves to rust, ever bought a mild steel wok and cleaned the waxy coating off for the first use? If you leave it damp it'll be orange in a minute. Just purge all the rust off, it shouldn't be deep yet. Mig welds are porous so it's a bitch to stop this happening. my usual is zinc primer before welding, and lots of coats of stonechip paint afterwards. Then Bilt-Hamber Dynax cavity wax on top.
