Duvel78
Website Admin
Posts: 2260 Joined: 29 Dec 2003 01:33 am
Post
by Duvel78 » 27 Jun 2005 04:08 pm
Mine is dead after 165.000 km
Take a look!
V3M for life!
RandomHero
Posts: 619 Joined: 04 Oct 2004 01:41 pm
Post
by RandomHero » 27 Jun 2005 04:20 pm
And all that time you wondered why it wasn't running so well
- 360 GLT, 1989, Gray Metallic, 115.500 km, PAS, Electric Sunroof, Windows and Mirrors
5lab
Posts: 3454 Joined: 31 Jan 2004 01:44 pm
Post
by 5lab » 27 Jun 2005 04:22 pm
sure its not been replaced before?
Duvel78
Website Admin
Post
by Duvel78 » 27 Jun 2005 04:34 pm
RandomHero wrote: And all that time you wondered why it wasn't running so well
Starting the car was slow, too slow! I hope there will be an improvement with a new distributor cap and rotor...
V3M for life!
RandomHero
Post
by RandomHero » 27 Jun 2005 07:53 pm
It must be a lot better, or there is something else on...
wjp01908
Posts: 210 Joined: 25 Jul 2004 03:35 pm
Post
by wjp01908 » 27 Jun 2005 07:57 pm
Is it just me or does the 1.4 just eat dizzy caps......
Will
You only need two tools: WD-40 and duct tape. If it doesn't move and
it should, use WD-40. If it moves and shouldn't, use the tape.
Posts: 1673 Joined: 15 Aug 2004 07:39 pm
Post
by pettaw » 27 Jun 2005 08:59 pm
Frankly IMO they all do. Its almost a service item every two years or so, check and replace dizzy cap and rotor. Cheap insurance for the trouble it causes if it goes all wrong.
bodejodel
Posts: 1155 Joined: 24 Jan 2005 01:41 pm
Post
by bodejodel » 27 Jun 2005 11:30 pm
I replace the spark plugs, leads, dustributor, etc... of my 1.4 in my Daf Coupé every year or at least every 5.000 - 10.000 km...
Jeroen
Posts: 9600 Joined: 18 Jun 2004 11:53 pm
Post
by Chris_C » 28 Jun 2005 11:31 am
Agreed with Will, Kar's gets replaced every year, which is around 12000ish miles. Is the B200F like this??? I'm gonna need some help soon understanding how new stuff works, it needs a lil lbit of tlc (only looks like the basics) Also, can't find any recepts for the timing belt being done, is there any way to inspect, and can I do it myself??
RandomHero
Post
by RandomHero » 28 Jun 2005 12:32 pm
Off topic
What is TLC?
On Topic...
Post
by pettaw » 28 Jun 2005 07:24 pm
If you can't find any record of the timing belt being done, just do it anyway. The original Volvo proper belt from a dealer cost less than 15 quid. The only difficult bit is getting the **##?? crank pulley off. Rather a tight nut, to say the least. Then its just a case of lining up the marks properly and off you go.
Posts: 5471 Joined: 25 Apr 2005 06:52 pm
Post
by classicswede » 28 Jun 2005 07:36 pm
I change the oil in my 340 1.7 now 2.0 every 10,000 miles(on lpg oil does not get thinned by petrol) and change plugs leads cap and rotor every other oil change approx every 5 months for oil change.
antiekeradio
Posts: 697 Joined: 04 Jan 2004 10:53 am
Post
by antiekeradio » 28 Jun 2005 11:05 pm
only thing I ever check/change is sparks plugs.
just leaving the rest alone until it goes bad has never stranded me.
on the other hand, I do change the oil quite often..
Post
by Chris_C » 29 Jun 2005 11:01 am
Cheers Andy, I will get that done next week hopefully then. Is it in the Haynes? I don't have a Russek for this one yet, but I did get an Autodata with it that I havn't really looked through.
