DaveGuy46
Posts: 57 Joined: 02 Mar 2011 11:04 am
Post
by DaveGuy46 » 10 Dec 2012 08:58 pm
Hi Guys,
Just need a quick answer as ill be ordering an R1 carb manifold soon from Bogg Brothers.
Are the F7R and F7P inlet designs exactly the same ? I think they are ?
I have bought a F7R with F7P head as far as i know, just dont want to order an F7P if it turns out to be an F7r and wont fit !!
Attack2001
Posts: 1015 Joined: 05 Jun 2011 03:45 pm
Post
by Attack2001 » 14 Dec 2012 03:32 am
Yes the inlets are the same
Thomas.............
EDIT - no there not! haha
Attack2001 on 14 Dec 2012 11:11 am, edited 1 time in total.
Posts: 9600 Joined: 18 Jun 2004 11:53 pm
Post
by Chris_C » 14 Dec 2012 11:00 am
It depends, a Megane F7R isnt
Attack2001
Post
by Attack2001 » 14 Dec 2012 11:12 am
haha i remember trying the f7p inlet flange on the f7r now... they are different indeed, if i recall correctly the inlets on the megane are different, and are actually smaller than on the f7p cylinder head?
Thomas.................
Post
by Chris_C » 14 Dec 2012 03:56 pm
Inlets are indeed smaller.
A Williams F7R has the same bolt fixing as an F7P, but the ports are a snadge smaller if I remember correctly, with bigger valves further down the line that doesn't affect the above question.
DaveGuy46
Post
by DaveGuy46 » 17 Dec 2012 03:07 pm
Cheers Lads,
Im pretty sure its an f7p head i remember being told its an f7r megane block (bigger oil pump) and larger valve head.
I take there is no why of telling. I.e head casting numbers ?
Posts: 3657 Joined: 31 Mar 2005 09:01 pm
Post
by 340GLT » 22 Dec 2012 09:55 am
The block will have an alloy tag on it if you follow the dipstick tube down to the block, if its
F7R 700 its a williams block
F7R 710 megane block end belt driven pump
F7R 714 megane block end chain driven pump ( no good as doesnt clear 340 sump)
