Hey guys, quick question;
I understand Volvo 360s have a 4x100 bolt pattern with quite a small centre bore; does that mean any of the huge range of 4x100 wheels (BMW, VX, smaller JDM stuff, VAG, etc...) would fit on it with the right spigot ring adapters? How/where can I get some adapters?
4x100 wheels; just spigot rings needed?
Re: 4x100 wheels; just spigot rings needed?
In the rare case that you find some cool wheels with an even smaller center bore, you'd just need to machine them to get them to fit on the larger bore.
You COULD do what I do and use tapered wheel nuts with tapered wheels whilst using your eye when putting the wheels on, honestly it's never failed me. As long as you don't tighten up one bolt all the way first. That's the beauty of wheel studs over wheel bolts.
as said yea, ive had a few whels on mine,
vauxhall on the front, mx5 on the rear:
some shitty bmw 15's on rear:
