Trim Moulding
Trim Moulding
Hello everybody..
Today's request is Trim Moulding for front and rear bumper for volvo 360 GLE year 1989..doesn't matter used or new as long as it still flexible, i need it for my new bumper front and rear.. postage to Malaysia. brand new is better. Anybody can help me source it? thanks.
Zack
Zack
OWN:
89 Volvo 360 GLE
89 Volvo 360 GL
89 Volvo 360 GLS
Owned:
01 Volvo S40 Phase 2 Turbo
84 Volvo 240 GL
89 Volvo 360 GLE
89 Volvo 360 GL
89 Volvo 360 GLS
Owned:
84 Volvo 240 GL
Re: Trim Moulding
Will any of this sort of stuff do??
http://www.carbuildersolutions.com/uk/chrome-edge-trim
http://www.carbuildersolutions.com/uk/chrome-trims
http://www.clevelandpanels.com/ford-fie ... ition.html
http://www.ebay.co.uk/itm/3M-x-3MM-Chro ... 3383493793
http://www.ebay.co.uk/itm/5M-x-6MM-CHRO ... 27d0a29425
http://www.ebay.co.uk/itm/1m-Chrome-Car ... 2335e3f449
http://www.ebay.co.uk/itm/Silver-Tone-G ... 35dbddd48e
Bend it and glue it into place?? Mind you, they are self-adhesive. Just need to get the rough diameter and then refine your search on ebay - the last link lets you select the size you want and its closer than the UK, well maybe, but my geography is not too good.
I don't know how the bumper trim strip is held in place, but others will. Going a bit mad but there's plenty to be getting on with here.
Re: Trim Moulding
Or do you mean the black bumper middle insert, used on all 340/360 1986 on.
I think only 340s used the chrome trim.
Re: Trim Moulding
thanks bogbasic, but that's what not in my mind. I have to agree with Ride-on, it's the black bumper insert. I bought front and rear bumper brand new, but they don't have this middle insert, mac have the diagram but he don't have it, it's label number 1 and 23
This is the part number
MY86>
1) 3209208 - Trim moulding (Chromium) / 3212945 - Trim moulding (Red) / 3213238 Trim moulding (Blue)
23) 3209118 - Trim moulding (Chromium) / 3212944 - Trim moulding (Red) / 3213234 Trim moulding (Blue)
Do you have it ride-on?
Post to kensington court.
Rgds
Zack
MY86>
Rgds
Zack
- Attachments
- bumper diagram
- bumper.JPG (64.3 KiB) Viewed 86506 times
OWN:
89 Volvo 360 GLE
89 Volvo 360 GL
89 Volvo 360 GLS
Owned:
84 Volvo 240 GL
89 Volvo 360 GLE
89 Volvo 360 GL
89 Volvo 360 GLS
Owned:
84 Volvo 240 GL
Re: Trim Moulding
I have a spare one from a 340, I think its the same, condition is not great but not cracked, maybe a little scuffed or gouged. Will check it out tonight. Posting could be tricky but I'll see what I can do.
- trabitom99
Re: Trim Moulding
I think the bumper trim can be rolled up quite well. I bought a NOS piece off the bay a while back, and the parcel size was reasonably compact ...
Re: Trim Moulding
Man, I know its not exactly the same part but I was suggesting that with some improvisation it could be persuaded to do the job, with a bit of rolling or trimming, etc!! I might try myself one day. It seems you can get black ones too.
Hey man, the plan is that I will kick myself out of bed earlier than usual tomorrow morning and have a hunt for the things you asked for, but please keep reminding me as I tend to forget about these promises very quickly.
Re: Trim Moulding
Sorry I'm confused I thought you wanted 2 or 24. 1 and 23 are not used on 360s AFAIK.
Re: Trim Moulding
Yap, I don`t have neither 1 or 23 on my `86 GLT.
the early bird gets the worm
Re: Trim Moulding
It's ok bog basic take it easy, there is still time, my friend will check out on 6th december. May i know where you bought it trabitom? please let me know if it's NOS. Yes ride on it's number 1 and 23 i need it both to complete the bumper restoration. If there is none, i may consider bought it from ebay as you suggested bog. Thanks man.
Rgds
Zakaria
Rgds
Zakaria
OWN:
89 Volvo 360 GLE
89 Volvo 360 GL
89 Volvo 360 GLS
Owned:
84 Volvo 240 GL
89 Volvo 360 GLE
89 Volvo 360 GL
89 Volvo 360 GLS
Owned:
84 Volvo 240 GL
Re: Trim Moulding
Hey man, I made it up to the roof this morning and found most of the stuffs....
1- Bumper bracket for rear bumper..GLE and GLS
I found these... from memory the part numbers end 328 and 329.
2- Window washer reservoir with pump for my GLS and pump only for my GLE
Found a good-looking one with two pumps. I would normally have wanted to keep the pumps but you had better have them.
3-Side bumper indicator lamp a pair of it
Still looking for these. I have two which are on a bumper so if you are really desperate, I can take them off.
4-Clock's if possible
I found a decent centre-console tick-tock clock. I will try to test it later.
5- Engine wiring loom, perfect condition for my GLE i want to redo the wiring.
Sorry I don't have this.
6-Air condition dashboard panel , mine got lot's of crack especially the center console, would be great if you can get all set.
Sorry I don't have this. I have a couple of heater control panels for the standard UK 340 but not one for air-conditioning - I don't know how this looks!?
7-Lowering blocks 2"
8-head light refelctor "i saw one pair advertised in classicswede"
I found my two old headlights. The reflector on one is quite good but not perfect. The chrome plating on the other one has tarnished quite badly at the bottom due to a hole in the glass. I was wondering - if you have reflector, can you get them re-plated locally???? There must be someone doing that sort of thing around your part of the planet. If you still just want the reflectors, I can dismantle the headlights which will obviously take a bit of time although it will save a lot of weight.
9- Roof cloth material "in perfect condition' for my GLE i saw one advertise in offering section.
10-Blowe motor running condition.
I found a decent-looking blower motor. I will try to test it and let you know.
11- Bumper caps the square one if you have a pair of it.
I found a pair of these but I would really like to keep them as they are so sought-after but if you are really desperate I would consider an exceptional offer which must be made in writing to my solicitor, I jest but you get the gist ;-0
13-Volvo 300 mania stickers
14-Volvo 360 GLE/GLS hanyes manual books
I can do you an old one - its the blue one for up to the mid-80's I think. Is that any good or do you need one for the later models. Again I have a couple of spares but I would rather keep them... oh, blow it, yeah man, if you'd like a brown one, just let me know.
15-Fuel pump relay, for spare in case.
16-Arsenal home kit tehehehe
17-bumper list between the bumper there is a list a rubber i think both front and rear
18-cigerrete burner
I didn't find this but I am sure I have one somewhere.
19-volvo number plate holder a pair of it
20- Electric side mirror a pair of it
I'll take a picture of this at the weekend so just let me know.
18-cigerrete burner
Re: Trim Moulding
This weekend? with picture !! great.. is it a hassle for you to deliver all the parts to kensington? any way let us refer your picture first..of course i'm in a desperate mode right now..it's like waiting my bride
. This chance not come often man.. imagine how much i can save on the shipping. my friend will check out on 6th dec..9 days to get all parts to his hand.
-the part number for bumper insert is perfect. I just need the rear one ending 329. a pair please.
-I've tried and ask local club member on headlight reflector restoration and i even look on youtube, they chrome plated with steel not plastic. Since you have it with good condition i better take yours.
- please take off the bumper indicator lamp with the wiring harness.
-bumper caps please.
-and clocks
-thanks for the manual
Thanks Man,
waiting for your picture this weekend.
-and clocks
Thanks Man,
OWN:
89 Volvo 360 GLE
89 Volvo 360 GL
89 Volvo 360 GLS
Owned:
84 Volvo 240 GL
89 Volvo 360 GLE
89 Volvo 360 GL
89 Volvo 360 GLS
Owned:
84 Volvo 240 GL
Re: Trim Moulding
It is only a small diversion for me to go to Kensington so I can deliver there any morning next week except Tuesday.
Re: Trim Moulding
I'm afraid these pictures are a bit doggy but they show the things I found.
The heater blower motor seems to turn with 12v applied to it but unfortunately I could not get the clock to tick so you can just have that and you may be able to repair it anyway. I will try to find a few more parts at the weekend. Let me know if you need any more photos to check the parts.
Re: Trim Moulding
HI Bog, the dog is asleep..looks tired and cold..ok just send it over, i saw the bumper cap, the clock, the precious GLE bumper insert, the washer reservoit and pumps, the heater blower, one question is this blower function the same as air condition blower? because i dont have heater in my car. Manual still not in sight as well as side bumper indicator lamp.
Thanks
Thanks
OWN:
89 Volvo 360 GLE
89 Volvo 360 GL
89 Volvo 360 GLS
Owned:
84 Volvo 240 GL
89 Volvo 360 GLE
89 Volvo 360 GL
89 Volvo 360 GLS
Owned:
84 Volvo 240 GL
