Hello, do anyone know how to change right Hatch Car Lift Support for Volvo 340/360?
Right one has gauge for interior light and my new one does not have.
Lift Support cahange
Re: Lift Support cahange
Hello, I seem to remember that the wire and the connector thing just slot on somehow so why not give it a try and see if you can sort it.... I think it should work OK, from memory of doing this a few times. I think I had to get the ball joint apart to slot the switch on to the rod or something - again its not too bad to loosen the spring-clip in the joint... my memory is very vague though.
Just undo the ballsocket and the switch just slides off so you can screw it onto your new ones
