Engine swap f7p details (wires connections)
Nolan
Post by Nolan »
Hello, i'm doing a f7p swap with a non cat loom wire and Ecu from a Clio.
My car is a 340 gl 1,7
I have looked the topic but need more information to connect some wires i can't see on the pictures...
Engine is inside, i'll need an external fuel pump too, and connect it, but need to know which wires from the Clio loom.
I saw a 3rd black wire connected on the starter motor wire, where is it going exactly?
There is 4 or 5 relays, anyone knows what it is, and if there's a fuel pump relay? And wich wire i have to connect to an external fuel pump?
Ignition coil wire, i think i'm ok but i can't see where the other wires (1 wire in the middle and another with 2 wires) go
And finally these to connect too
I have found this, i think it can help!
http://s70.photobucket.com/user/24175my ... 1.jpg.html
