340 cvt for raid
Bor
340 cvt for raid
Post by Bor »
Buenas first the intro:
viewtopic.php?f=83&t=16503&p=189366&hilit=bor#p189366
and
viewtopic.php?f=83&t=16675#p190740
will tell you the back ground.
We have a 1986 340 cvt with B14 4E for 2017.
We know what we want but are not familiar with the 340 and wonder if your experience pool can help us find the shortest route to obtain that.
We want:
- it higher on the springs
- less understeer
- sump guard
- more grunt/midrange
- low ratio of cvt at low revs/speed, possibly on switch
- Volvo 300 GT or ATS Classic alloys
- braces on front and rear struts supports
Thanks for any info/tips
Re: 340 cvt for raid
I have rally springs for the 300 series or you could fit 360 front springs,
Better dampers and poly bushing combined with good tyres will reduce the understeer
Sump gard you will need to make
Front strut barec has to be fabricated on teh car
There are no rear stuts so fitted any kind of brace at the back would be silly
For more power a free flowing exhaust and perhaps upgrade to a twin 45 DCOE would be teh best bet
I am not sure if there is any way of changing the CVT gearing
I thought there was a low ratio hold button.
Would the negative camber on 360 struts not help?
What is a brace?
Bor wrote: - low ratio of cvt at low revs/speed, possibly on switch
Add a second switch to the low-ratio hold: http://forum.volvo300club.nl/showthread.php?t=9039
Bor
Post by Bor »
Thanks for the feedback.
Yes, the CVT can be quite easily improved for sports use by adding a switch to the EMVK and also by adding a one way valve in the lead to the inlet manifold and a reservoir for 'vacuum' .
The standard low ratio button stays in lowest ratio only. Very useful too, but limited.
For power upgrade I will stick to the standard DIR as the DCOE will cost as much at the low end as it brings at the mid/top. I have just dropped a K&N unit in the standard pan. It is also way easy to duct cool air into the standard filter housing with less intake noise as a bonus.
Found a source for a sports camshaft.
Sticking to modding the standard exhaust too.
The power gain will be nothing spectacular but the car will pass periodic inspection without hassles.
Still working out how much to have shaved off the head.
I am sticking with the standard springs at the front as comfort is quite a big thing on 11 hour camino stretches. Still looking at what to do at the front; space the strut at the top or add pre tension to the spring.
Yes the negative camber of the 360 strut legs would do a LOT.
For the back I have 'caravan' springs that go around the standard shocks.
Just received a set of alloys: period ATS 'classic'; 6J x 13 and ET 30.
They are lighter than expected so sm4
Bor
Post by Bor »
With back sorted out, thought a bit more concentrated about the front.
The standard springs will not do. They will not keep the car high enough off the gravel and the difference in spring rate with the rear is too large.
So I mailed Dai and I thought to share the info with you:
Buenas Dai,
The 340 full hight rally springs you have: Does that imply standard length? How much harder are they than the standard springs?
They would be a very easy 'fix'.
Why the shorter bump stops btw? Same length but harder so why?
Hi Petrus,
the rally springs are shorter than original but stiffer giving the same ride hieght. Custom springs can be made
They are easy enough to fit
The bump stops are a case of what fits and is available
Exactly what I thought and want NOT.
I like the standard springs but do need a bit more ride hight/wheel travel. The caminos here are quite a bit rougher than say the forest sections in the UK.
I want the car HIGHER and max wheel travel.
At the back the 'caravan' springs basically do the same: Giving more ride hight and not much stiffer rating.
I want that at the front too.
The springs that will work for you are http://www.classicswede.co.uk/Original_ ... 56819.aspx
they are a bit stiffer than original and will lift the front about 20mm on a B14. The springs are full length and would work well on a gravel rally car where the suspension needs a lot of give
Thanks for the link. It reads 'or lower other models'.
Meaning the standard, non GLT, 360 springs would be both standard length AND stiffer than the 340 springs?
I mean, the B19/20 is a good deal heavier than the B14.
If so, that seems to be the right medicine.
Yes they are slightly lower for a 360 but with less weight in a 1.4 it gives some lift but is still not a stiff spring. Just a less spongey than teh originals
Looked up spring specs for the various models and the regular 2.0 line has the same spring as the diesel.
It is 30 mm. shorter than the B14/17 spring but some 10% stiffer.
The standard GLT is again shorter and 15% stiffer still, resulting in close to 30% over the B14 one.
Tricky one.
With 30% less sag, I think that the 2 cm. you give is probably on the lowish side.
Probably about the same ride height as the standard 2.0/diesel ones.
Right. The ham question is how much firmer I want the ride.
30% is not that much and will keep the thing better off the ground and I am mounting 30% lighter wheels thus giving less jolt on the springs thus car.
Also it would balance with the stiffer rear.
Hmmm.
Instinctively I'd go for the 10% spring but the standard GLT could be just the thing.
Thanks for the suggestion.
I know when I fitted the GLT springs on a 1.4 it did lift it a fair bit but the old springs had sagged. The car felt factory fresh with them on.
So, I am going for the standard GLT springs Dai has had made sm18
Bor
Post by Bor »
Add 165/80 M&S tread recovers and have a few more centimeters plus more resistance against punctures because of the extra rubber recovering brings.
360beast
Post by 360beast »
Brilliant, hopefully you won't be bottoming out anywhere now :)
Bor
Post by Bor »
360beast wrote:Brilliant, hopefully you won't be bottoming out anywhere now :)
Well, there is always hope, but realistically there is more chance on winning the lottery :lol:
The main raid we want to do is some 2500 kilometers of dirt 'roads' through Spain, crossing several serious mountain ranges and two deserts. Very much comparable to an early eighties Dakar.
360beast
Post by 360beast »
It looks like a bloody good time, hope you enjoy it again and the 340 performs well.
Bor
Post by Bor »
Oh man, 8 days of incredible motoring fun.
So much so that we decided on 2017 during the event.
Although it is not a flat out race; not a speed event, for most of the route it is VERY hard to stay on the ball even with a relatively modern proper 4x4.
We are not aiming for a lot better, in fact not at all, better result that this year, but losing less time on the bumpiest going would make it all a dimension safer.
I think our 55M is quicker than our 340 ever will be, but way more wheel travel and ditto grunt is going to make a comfie world of differences.
