How to lower a 360?
How to lower a 360?
Hi,
I just wondered, how do you lower the rear of the 300?
Are there different ways to do it? And what is the best solution?
Thanks.
Thanks.
1987 - Volvo 360 GL B200K : 266000 km
The head nurse spoke up, and she said leave this one alone
She could tell right away, that I was bad to the bone
Nope your effectively just moving the mounting point between the leaf spring and the axel so no extra strain on the spring, I don't think you can go any/much more than 1" though due to something at the back, can't remember what it was though, glt leafs are also lower and stiffer
Ali
Ali
This is how to do it
classicswede wrote:While the forum has been off the development of my lowering blocks has finnished with pleasing results.
First off you will need some tools:
Jack, axle stand, wheel brace, 6mm hex key, 17mm spanner, a good half inch drive ratchet with a 17mm flat sided socket (left hand side of pic)
Fist off losen the wheel the jack one side at the rear up and then reve the wheel. Place an axle stand under the car incase of any problems.
Once you have done that the drive shaft needs to be removed from the hub(the diff end does not need to be disturbed).
Now you can get to the spring retaining bolts. Use the 17mm spanner and the 17mm socket to remove the nuts and bolts.
You can now slide the lowering blocks in and reasemble. Make sure you refix the shimes as they are there to reduce rubbing.
Well I must say even though I have loads of weight in the back and with the lowering blocks the front is sitting lower. It looks nice as it is now and I'm sure you guys will love it.
- huskyracer
Nice fitting guide Dai, Just to let you know, you can *just* get the retaining bolts out without taking the driveshaft out. 3 come out easily, the other one can be tapped out past the driveshaft by carefully aligning it to go between the bolts retaining the shaft and drifting it out with a small punch. Its fiddly and a bit crude, but much quicker. Only to be attempted by people with a bit of Knowledge in these matters, as it would be very easy to reck the driveshaft gaiter. If in doubt, do it Dais way!
You'll need spring compressors but other than that I think you just need some sockets and other spanners. Best to follow the Haynes manual. One thing I would suggest, the Haynes says to loosen the radius arm nut so that it gives more flex but I would say remove it where it joins the suspension arm (two bolts on a bar). Otherwise its really hard to get the strut to come outside the front wing,
Ali
Ali
If you do not have compressers then you can cut the springs to release the tension.
On the other hand you can do it the way it always used to be done in the old days; lowering blocks are just a cop-out from doing the job properly.
Simply remove the leaf springs, take them along to your local blacksmith (plenty around these days with the upsurge in horse-riding), and have him retemper them.
My dad had it done with the old Morris Traveller, and when building a Fairthorpe many moons ago.
Perhaps he didn't have them done professionally, or the guy doing the job was inexperienced?340GLT wrote:I think this is what Nev did to his and it weakened the springs and they snapped? I my be wrong though.
It's a proper forge job; I remember being taken along to see it done when I was a little kid - it takes a long time and is fascinating when you're young; when you're older I think you just admire the skill involved and the pride in doing a job properly.
Anyhow, my dad never had a problem with his cars, and if I get myself a 360 soon, I'm sure I'll go that route.
