How to hold the crank still on b200e?
Posted: 05 May 2006 07:02 pm
by Ali
As above ^^^
Went to swap the cam back to the original A-cam today and spotted a nasty slit in the cambelt so went and bought a replacement, spent all damn day getting the fan off (3 rounded bolts in the end and a lot of shouting and swearing!) but now I can't work out how to hold the crank still to get the nut off for the end pulley. The haynes book of lies tells you that there's 6 bolts on the end which would be a lot easier but instead theres just a massive central one! On my 340 I can see a window in the bell housing where you could jam the flywheel but can't see that on the 360 plus its too low to get underneath and I can't get it up ramps sm75
Re: How to hold the crank still on b200e?
Posted: 05 May 2006 08:21 pm
by Carl
Take the starter off and jam something in there? Put it in gear?
Posted: 05 May 2006 08:30 pm
by Ali
Nah its ok, Pettaw has sent me in the right direction... correct answer is remove the crank position sensor and jam a correct sized bolt in there. I did try leaving it in gear but theres just too much flex in it still needs to be totally solid
Posted: 05 May 2006 09:59 pm
by pettaw
yeah but be bloody careful that you get the correct sized bolt to jam into the hole cos those holes are the detection holes for the Renix unit, so any damage to them means new flywheel time.
Basically though, as long as you get the biggest bolt you can get in there, you'll be OK.
Posted: 07 May 2006 07:02 pm
I normally use an 8mm 1/4" drive socket.
Posted: 07 May 2006 08:12 pm
by jtbo
Hmm, I think there is hole at alternator side of engine, plugged but when you remove plug (or was it bolt???) there is hole and you can use that to keep crank still, that is reason why it is there ;)
Posted: 07 May 2006 08:22 pm
There certainly is on the B14 - near the starter. Again, I'd just use the crank position sensor hole :)
Posted: 07 May 2006 10:55 pm
by V6 Man
Just use a large socket and a long bar on the crank pulley and wedge the bar on the ground.
Posted: 08 May 2006 12:21 am
Sure it holds the crank still, but how do you then get the pulley off?! Back to the horlicks for you...
Posted: 20 May 2006 05:27 pm
by Chesh740R
foggyjames wrote:Sure it holds the crank still, but how do you then get the pulley off?! Back to the horlicks for you...
I think what rupert meant to add on the end of his little part, was with the bar resting on the ground in the correct orientation, you pull a coil lead and just flick the starter and voila, the engine undoes that stubborn bolt for you.
Used this method on an audi quattro once. Certainly makes you clench ya ass cheeks as you flick the starter.
