spot lamp brackets
spot lamp brackets
Post by redline »
Hi , do's anyone know where I can get a set of front spot light brackets that fit behind the grill and go above the bumper from ?, Blade has a set on his car (see announcements , the family we need your pictures page 8 ) but my local volvo dealer says they are not listed . I am trying to avoid drilling the bumper if poss
5lab
Post by 5lab »
you can get a grill with lights built in - is that what you're after?
Do you mean these type of fog lights? Pretty sure they're a Volvo accessory at the time, I remember seeing them in a brochure at some point. They must be pretty rare though.
Steve
Post by redline »
No , I wanted brackets to fit round spots on , check the front of blades car hes got them . never mind ,as soon as i sent the last post I went out and whipped the bumper off , drilled it and fitted the spots , just got the wiring to finish now.
Probably the easiest thing to do by drilling the bumper, should look pretty good with a couple of spot lights mounted on it. I saw your redline on ebay when it was for sale, its got to be one of the nicest 340s about - the redline interior is really nice too!
Steve
Post by redline »
thanks Steve , i'm really happy with it , I am getting her serviced soon to keep the history up to date . I was just lucky it was up the road from me in Northampton. New stereo is next on my christmas list (lol),I would like to lower it and fit different alloys so I can save the originals, I fancy something old school like mambas or minilites with black centres and ally rims.I would also like to get the door bump strips replaced with the ones with the red stripe in i have seen on some cars to keep the redline theme going. By the way has anyone got a large REDLINE sticker from the car mag as I want one for the top of the windscreen (dosn't need a sunstrip cos of the toptint windscreen .
5lab
Post by 5lab »
good luck lowering it..
i had a set of origional 300 series alloys a while ago - got them off ebay for 99p, but i didnt need htem so i let another enthusiast have them for free.. they were quite nice mind, and super-rare
Late style 440 alloys look good on 300s, and are of the same fitment (although I have heard of some discrepencies in slight offset differences - not enough to make a noticable difference I'd imagine)
There are various styles in 15"s which look the right size on 300s in my opinion! Should be cheap too.. from good ol' ebay :wink:
Steve
5lab
Post by 5lab »
james has got 15s on his, trouble is that you have to use relatively low profile tyres that cost a bit more.. and also you have to tell yer insurance if you add anything to a car which isn't origional
That's true to keep the same/similar rolling diameter of the wheel/tyre.
Also, bigger wheels don't tend to help with handling. With the same weight spread over a larger area of tyre, means theres less grip. Also, in the wet the tyres have more water to clear.. so grip is lost again. But look damn good!
Steve
Post by redline »
spot lights now fitted and working , thanks for all the help and advice guys. (now for the fogs )
Post by redline »
After the seat incident , there isnt much left of my old spot lights , I am going to get new ones and would like to fit them properly to brackets this time, I wondered if anyone could tell me where the proper volvo brackets bolted on ? i.e. are they fitted to the bumper iron or somewhere on the car itself , If anyone has a picture of the brackets , could they post it on here so I can get a copy made.thanks
5lab
Post by 5lab »
did volvo do brackets for late cars? if so, i dunno.. probably just under the grill somewhere
Post by redline »
BLADE , Just seen the pick of your car in bodykit group buy thread ,do you still have spotlight brackets on the top of your front bumper ? if you do can you tell me where they bolt onto and will you be taking them off when you fit your bodykit , If you want to sell them give me a shout otherwise I will have to get some made up. cheers mate
Didn't you once say that Nessy had a set of these brackets Hugh? Or am I going mad?!
