1.7 bogging down
voly340
1.7 bogging down
Post by voly340 »
ive got a 1.7 and trying to going round or coming out of corners hard the whole engine just bogs down and dies, then willl slowly pick up again by the time im out of the corner. ive replaced to dizzy cap as it was a bit worn, but it still does it, stripped the carb and that looks fine. the spark plugs look alright aswell. thought it could possibly be the choke sticking aswell, but it isnt.
i have no idea what would be wrong. any ideas or help?
MJ
Post by MJ »
I'd say it's the carb. Float height adjustment out probably. This can be adjusted and should cure the problem, although the fuel will always slosh about in there, so it may not entirely fix it.
Here are three previous posts on the same subject :)
http://www.volvo300mania.com/forum-uk/v ... php?t=4712
http://www.volvo300mania.com/forum-uk/v ... php?t=4669
http://www.volvo300mania.com/forum-uk/v ... php?t=3487
Hopefully that'll fix your problem. Oh, and welcome to V3M; do ask if you have any more questions :)
MJ is right, mine does it at the mo, and you can smell the extra petrol when it bogs.
However, I have no idea how the floats on mine wandered over 6 months or so.
Oh, add to that if you read those threads... check whether the ball bearing should be compressed or not, it's the opposite of what I thought it was when I set it!
voly340
Post by voly340 »
cheers for the replys. good to see its a comon problem in a way. should have really done a search before i posted a new topic, ah well :) ill take the carb off tonight and have a look
:D
Me and Andy sorted mine over the weekend... and she's sooo much smoother again. Not to mention I've gone from 25-30mpg to around 45... with me "testing" that is doesn't bog a fair amount :lol:
voly340
Post by voly340 »
ive reset the gap to 33.7mm, it was about 5mm :/. but now it will only tick over at around 3k and if you try to turn the idle screw down petrol starts pissing out of the round vacuum hole thats covered by the small bit of black rubber so i dont know what to do. Just get a new carb?
I think you've measured the wrong gap mate, the floats on their own are already well over 20mm. You need to measure from the base of the gasket to the TIP of the floats, not the bottom.
I can't really explain any better so you need to see a picture. See if there's a cheapy Haynes going on Ebay or something. Tbh even if you have to buy one at full prices its gonna save you a bundle in bills.
I've just raided my baggy of spare bits, and hopefully this pic will be helpful. Imagine the laptop is the carb top plate (all out of solex top plates here!) and the red line should be the 33.7mm.
