Air conditioning 1988 - 19.. (german)
Post by trabitom99 »
I took some pictures of the 1988 air conditioning green book yesterday as I may be having LOTS of questions on the subject soon ...
The pictures are of poor quality and the text is in German, so it's probably not worth moving to the resources section, but I'll let the mods be the judge of that. Also I've left out several pages - those with only German text, and the diagrams of how to take the Sanden SD510 compressor apart - I guess most people wouldn't bother as it supposedly isn't compatible with the ozone-friendly R134a gas.
Construction and functions of the A/C
Basic principles of the A/C
Method of operation
Layout of a cooling system
Evaporator
Condensor
Thermostatic expansion valve
Compressor
Drier
Idle speed equalisation
System monitoring / protection
Compressor in a car without PAS
Compressor in a car with PAS
Removing / fitting / checking the evaporator and thermostat
Removing / fitting various A/C parts
Preperation
Replacing the expansion valve on the evaporator
Removing the condensor
Fitting the condensor
Removing / fitting the drier
Removing coolant hoses (general)
Changing coolant hoses
Checking the temperature adjustment valve
Changing / checking the thermostatic expansion valve
Fitting a pusher (?) fan
(older specifications can suffer from temperature problems. In this case it may be necessary to fit an additional pusher fan)
Some close-ups of some of the diagrams:
[1] Condensor
[2] Compressor
[3] Evaporator
[4] Filter/drier
[5] Expansion valve
[6] Pressure switch
Solenoid valve (Idle speed equalisation) B200E
Heater valve, air con switch [3] and vaccuum recirculation switch [2]
Removing the evaporator and thermostat from the heater box
Evaporator and condensor
Fitting an auxiliary fan
03.01.08 Headings edited
An update to add the wiring diagrams, courtesy of mac:
http://www.volvo300mania.com/forum-uk/v ... php?t=3311
meintag
Post by meintag »
Wow... THANKS a lot man !!! Very useful information :wink:
Greetz from Spain !!
