B19A - What can be made to this engine?
340cbr
Post by 340cbr »
There is a 364 GLS with the B19A for sale here.
Is this engine any good? What can be made to increase power without swapping the engine?
Is the fuel injection system plug&play? Since I had the B172K that I don't like carbs :roll:
Thanks in advance for your replys
| 92' 965 Turbo 16v | B204FT - 190hp |
Had: 90' 340 GL + Turbo | B18 FT | Koni's | Alpina White |
Ronnie
Post by Ronnie »
I have the B19E.
B19's are reputed to have stronger internals than the B200. They are quoted as having the same BHP as the B200's, but many people feel they have a bit more usable power than the more modern engines. Inlet manifolds are available to fit twin 40's and possibly 45's if you're sticking with carbs. But setting up the correct jetting on aftermarket carbs is a black art which I don't pretend to know anything about.
I guess you could swap the FI system from a B19E if you can find one - but for all the hassle it entails you might as well put in MegaSquirt and get some proper power improvements
http://www.filterfeeder.eu
Fuse
Post by Fuse »
B19A engine in the 360 is the best engine for bolt on turbo, it has compression of 8.5 and strong internals, so if the engine is in decent shape just slap on a turbo, sort out the fueling and ignition, and you are good to go. 8)
340cbr
Post by 340cbr »
Is possible to swap in Turbo getting the injection system from let's say... a B200FT?
Fuse
Post by Fuse »
Hmm.. Well LH-Jetronic 2.4 and Motronic needs their own flywheels for the ignition, so the flywheel has to be changed if you wan't to use either one.
LH-Jetronic 2.2 doesn't need specific flywheel as it uses hall-sensor in the dizzy for the ignition, so a LH 2.2 from a turbo model would work with most less work. :P
700-series with B230FT had 2.2 LH-Jetronic. I think all 900-series turbos are 2.4. B200ET and B230ET in 700-series were with Motronic.
I don't know which the B200FT had as those are not so common in here. :)
340cbr
Post by 340cbr »
Here we had B200FT/ET in 700 and 900 2.0 Turbo's
What about the 240 turbo?
Thanks
The B19 has a much better carb then the later engines. Its a good little lump and IMO revs better than the later B200.
