volvo 360gle no revs limiter
FA360GLT
Post by FA360GLT »
My volvo 360 1988 engine b 200 And does not the revs.limiter work probe with another unit of ignition and, the revs.limiter this where either?. If I place a unit of ignition 408 it brigs revs.limiter?
Pappa
Post by Pappa »
Not all 360's have a rev limiter. If you change the Renix to a newer one you might get a rev limit.
mac
Post by mac »
A renix type 408 has a rev limiter (408 is from an 86 B200E)
Mac
FA360GLT
Post by FA360GLT »
Thank you I am going to install the ignition 408
There are B200K renix units with and without limiters. My B200K has a limiter at around 6200rpm. I can't remember which renix code it is, off the top of my head.
Post by trabitom99 »
Here's the sticky post concerning the Renix type numbers (very useful).
http://www.volvo300mania.com/forum-uk/v ... php?t=3506
...which I was too lazy to find last night :)
Jason B
Post by Jason B »
tbh I've never even considered whether or not it ever had a limiter, it makes all the torque so much lower down the rev range that I never really push the car to far up the revs (and that is with some spirited driving too)
FA360GLT
Post by FA360GLT »
My 360 gl 89 b200 k has rev limiter (414). probe the unit renix of my glt in the gle and I do not rev limiter is 411a . The gle unit of ignition in the glt I limit to 6200revs (411a).I could not have proved the 408 unit
I don't think I found it until I put on the 40s & the K cam ;)
Jason B
Post by Jason B »
To really embrace revs near 6000 you need one of these maybe:
;) :D
Not really....there's almost no difference at all. I think the H has 2 degrees more duration, and accounted for 4bhp in the 240 GLT. ;)
Cool to have for the post factor, but not worth squat over a K in practical terms, if you ask me. Did you get one in the end? If so...cool :D
Jason B
Post by Jason B »
also depends what engine you are sticking it into as that little bit extra goes much further on a 2.3 :) yes it looks like I do have myself one with an adjustable gear too :D (and both together for less than you'd sell a k cam for :P )
Just a tip...don't expect to get the full potential out of it using the standard EFI inlet manifold. Pettaw started measuring vacuum on his inlet manifold at high RPM on a B200 (with a K cam), never mind a B230. The B230 is something of a mixed blessing. You obviously get more power, but the benefits are perhaps not what they should be. For a start, the 'just about right' sized cylinder head starts to become a bit of a hold-up with the extra displacement...and headwork is usually a higher priority on an NA than a turbo, pound-for-pound. Still, a nice cam, a huffing big intake and exhaust, and having it balanced for 7krpm should net you ~200bhp.
Sounds like you got a sweet deal. I'd run it timed straight up, even though you have the gear. I'd only use one to correct cam timing errors (for example) introduced by skimming the crap out of the head to bump compression.
Jason B
Post by Jason B »
tbh I'm really not too worried about making loads of power, I'm only aiming for around 160bhp which shouldn't be too hard considering a b230fb makes 130 stock and it is proven that an H-cam and bigger exhaust will nearly achieve 160 alone, then getting a decent torquey ralliable engine shouldn't be too hard. (160bhp/ton is more than enough with stock rear suspension setup!)
