Blinking too fast
Pappa
Blinking too fast
Post by Pappa »
When i blink to the right it's blinking very rapidly, what can this be? It's normal sometimes, but it's gotten worse lately. Blinking to the left is fine.
Post by filthyjohn »
This is normally a blown bulb. One of the three will need replacing, or might have worked loose. Should be an easy fix.
MJ
Post by MJ »
Yeah, Johns right, it's usually a sign of a bulb not working, although it could be a bad earth rather than a bad bulb or dodgy connection. This would explain why the speed is normal sometimes and fast others.
Pappa
Post by Pappa »
Well, both my side blinkers are messed up. Thanks, didn't know this could happen from a broken bulb!
Its the reduced loading that does it
