340 steering wheel boss
Bobalob
Post by Bobalob »
Hi,
I have heard the 205 boss can be used but apparently they differ after 1988 and I am unsure which will fit, I have a 87' 340 1.7
Thanks
robbie d
Post by robbie d »
(SNAP)
i was just about to ask the same question lol can anybody help please? :roll:
Bobalob
Post by Bobalob »
good luck its been up a while and yours first reply :P has taken a back seat since my diffs blown up but if you find out let me know.
if not ill prob take a stab at a random ebay boss
kaos
Post by kaos »
i do believe it is the GTI boss.
Post by filthyjohn »
I think all 205 wheels are the same spline pattern as 300s, I've had a wheel from a base model 205 on and it fit, but as for indicator cancelling and horn pushes, no idea.
cheshire190e
Post by cheshire190e »
i had to use a 205 boss. then unclip the plastic bit from the 300 wheel with the horn sensors on. chop the indicator cancellor of the 205 boss then press the plastic bit from the 300 wheel onto the 205 boss
1987 Volvo 340 1.7
J340GLT
Post by J340GLT »
I have a momo one spare if anyone wants it..£30, may need to get the horn push ring from a normal 300 steering wheel though for indicator cancelling purposes
Jay... bring that boss to the BKV ;)
hodgy21
Post by hodgy21 »
http://cgi.ebay.co.uk/OMP-Boss-Kit-Peug ... 18Q2el1247
This boss has the correct spline and fits the smaller pcd (70mm?) omp, sparco style wheels. the actual boss is longer than the one in the picture, and you will loose the self canceling stalk, and you will have to find a new way of connecting your horn.
or you can go to Halfrauds and just ask for a volvo 340/360 steering boss from them which will fit a mountney style steering wheel (larger pcd 100mm?). this one will also accept all the indicator jiggery pokery and horn push devices!
Saw there were a lot of models of boss for the peugeot 205, and I went through them all to find the right one.
Good luck mate. :wink:
