Help needed urgently
Greetings from new zealand
I need to adjust the handbrake in my 1985 360 as it only just comes on at the very top of the ratchet
how do i adjust it as i need to fix it for my warrent of fitness tomorrow(our version of MOT)
alex
alex
From memory it can be adjusted on the hand brake lever. Where the cable comes through you can tighten the nut (10 mm?) to pull more tension on the cable.
Have you taken the trim off to get to it?
cheshire190e
hi,
If you get under the car, you will see the handbrake cable going into a clamp which then goes to both back wheels,
O--------------------handbrake cable
abit like that ^ haha
anyways, where the handbrake cable goes into this clamp its held by a nut, just tighten that up a bit. be carefull not to overtighten it though.
Hope this helps
Matt
Hope this helps
Matt
1987 Volvo 340 1.7
cheshire190e
cheshire190e
cheshire190e
