360 A/C - R12 to R134a conversion
Posted: 16 Aug 2009 10:00 pm
This week, I removed the air conditioning system from a pretty rusty MkIII GLT. It's an aftermarket system (from Deltamil Nederland), so removal was fairly straightforward, although putting it all back together again will be a bit fiddly!
The system was running on the ozone-friendly R134a gas before it was bled a few months ago, but judging by the "R12" inscription on compressor and hoses, it started life as an R12 system.
Here's a quick overview of the system:
Condensor, filter / drier and aux fan (note the non-standard location of the drier - fitted to the condensor with tie wraps!):
... with a close-up of the part no, and the dimensions (maybe interesting for someone?)
Compressor with PAS mounting bracket:
Compressor part no: (note "R12" on the label)
the thicker hoses leading to / from the compressor say "R12 Freon" on them, one isn't in that good condition:
the thinner hose between condensor and expansion valve:
Switch on the heater box, one leads to the A/C switch, one via a fuse & relay to the pressure switch on the filter drier, and from there to the compressor
A/C button wiring - one goes to the heater box, the other to the fan switch:
Vaccuum for the air recirculation switch (also looks like it's retro-fitted) -
There was no idle speed compensation, no full-throttle cut-off, and no extra coolant temperature sensors to turn the extra fan on and off, I guess it just turns on together with the compressor.
Basically my question is - what do I need to get hold of before fitting it all back in (part numbers maybe?) and refilling it with R134a?
Going through one of Andy's old posts:
How can I check if the fittings on mine are those for R134a? The OE part number for the drier is 3206858 - but if I search for that I get parts which are designed for R12. Any advice on which drier to get? I'm also not sure what to look for when looking at pressure switches (R134a is filled under higher pressure, right?)
http://www.volvo300mania.com/forum-uk/v ... ?f=5&t=337New drier about 50 quid
New O-rings and ester oil about 20 quid.
Conversion fittings about 20 quid.
