I'm finding that after the car has been on the road for a while the gear change between 4th and 5th is a little crunchy, as is reverse. I think the clutch might be dragging a little bit, how do I adjust the cable to compensate for this?
I’ve not done this before but I can see that the end of the clutch cable has a threaded section, do I need to tighten this up?
Thanks,
Alex
Clutch cable adjustment?
Re: Clutch cable adjustment?
Trial and error got me there in the end, not a tough job at all
Alex
Alex
was the diagnosis: dragging?
If the clutch is not fully disengageing then tighten it. If slipping lossen
