Bolt pattern and ET on Volvo/DAF 66 wheels?
Tero Huikko
Post by Tero Huikko »
Checked out all the books but didn't find any confirmation.
Anyone have knowledge on this?
Volvo 66 GL 1975
Volvo 66 GL 1977
Volvo 440 DL 1994
Volvo V50 1.6DRIVe 2009
Mercedes-Benz 190E 1992
Oldsmobile Omega 2.8 V6 1981
Tero Huikko
Re: Bolt pattern and ET on Volvo/DAF 66 wheels?
Nope. 66 has a 3 bolt pattern.
Volvo 66 GL 1975
Volvo 66 GL 1977
Volvo 440 DL 1994
volvodspec wrote:3x 108
No, it's 3 x 125mm PCD, nothing similar to Renault or Peugeot. It's a DAF oddity. It'll be 10 days before I can tell you the ET, the stud hole diameter and the hub hole size. (In Glasgow at present, all my books are Dublin)
Here's the page from the DAF 66 factory manual I made earlier :D :
Volvos had "Marathon" spec steel rims.
Various alloys were made. Most recently the DCN had Minilites made with the custom drilling. Other old stuff can be found here ;)
Tero, Can I ask why you want this information?
Post by volvodspec »
bolt pattern is 3x108, pcd is 125.
bolt pattern is the distance between the bolt holes
PCD is the diameter of the circle which passes through the centre of all the bolt holes
bolt pattern on a 3x108 rim has a pcd of 125
Tero Huikko
Why I want this information? My car where I could measure these is away at the museum (70 miles).
I'm thinking of buying a project car and thought of the minilites.
If I buy a project car I could do all the pervert modifications that I just couldn't do on previous one.
What other cars have 3x108? Peugeot 106 has 3x98? Renault 5, Citroen Visa have 3x108?
Peugeot 304's have 3x108?
The ET's a mystery
Basically I would like to tune up the engine&chassis and make the wheels larger and wider. Perhaps 6x14" alloys with 195/60R14 tires.
Just searching for the alloys before putting my money on the car.
Volvo 66 GL 1975
Volvo 66 GL 1977
Volvo 440 DL 1994
Citroën AX
Citroën Saxo (some models)
Peugeot 106
thats all I can find in 3x108.
Tero Huikko
Early saxos and 106 had 3x98
Volvo 66 GL 1975
Volvo 66 GL 1977
Volvo 440 DL 1994
Tero Huikko wrote:Early saxos and 106 had 3x98
hmmm, the info on the website I was looking at must have been incorrect then. :?
Tero Huikko
Yup.
http://cgi.ebay.co.uk/3-x-15%22-three-s ... 590wt_1165
This would've been too easy way out.
Volvo 66 GL 1975
Volvo 66 GL 1977
Volvo 440 DL 1994
Tero Huikko wrote:If I buy a project car I could do all the pervert modifications that I just couldn't do on previous one.
well if it would be a project car, why not a converion to 4 stud with 4x100 pattern?
Or 4x108 if you want cheap minilites. :wink:
Tero Huikko
Why's that?
Volvo 66 GL 1975
Volvo 66 GL 1977
Volvo 440 DL 1994
well i've heard that the front wheel bearing of a d66 is the same as a v3s one, so that would mean just swapping the hub over and possibly fabricate a bracket for the caliper.
i believe that if you take apart a v3s rear beam you might be able to do the same trick converting it to 4x100
