wheels sizes
Re: wheels sizes
not sure if re-calibrating the speedo is that simple - think eveyone using different sizes from standard just guesses.
mine just scrubbs the rear arches with 1" blocks and GLT springs on 195/45 15's on 8J. fronts are fine
Re: wheels sizes
Yea i still haven't blocked mine yet.
Own:
86 & 89 360GLT
00 S80
01 Subaru Lancaster 6
02 Subaru GT30
Owned
86 & 89 360GLT
00 S80
02 Subaru GT30
Owned
Re: wheels sizes
The bigger rolling radius will help correct the speedo. Almost every 300 series speedo reads about 10% fast
Re: wheels sizes
195/45 15s on an 8J makes em smaller than standard so mine will be out more than 10%, yeah?
Re: wheels sizes
I was on 195/50 and that was still 10% slow. When I changed to a 440 speedo that corrected the reading to almost spot on.
Re: wheels sizes
So mine should be fine yea?
Own:
86 & 89 360GLT
00 S80
02 Subaru GT30
Owned
86 & 89 360GLT
00 S80
02 Subaru GT30
Owned
Re: wheels sizes
You will be fine. Just check your readings with satnav so you know where you are with it. You will still probably be reading fast.
Re: wheels sizes
Thanks heaps its one of those things that's been on my mind for a while.
Own:
86 & 89 360GLT
00 S80
02 Subaru GT30
Owned
86 & 89 360GLT
00 S80
02 Subaru GT30
Owned
Cliché Guevara
Re: wheels sizes
VW Honda Vauxhall all are 4x100 stud pattern. search egay for 4x100 and google the meaning of the et if you are not sure. What its all about.
Re: wheels sizes
I have found nice set of R16 9j ET20 wheels with 215/40 tires. For upcoming season I am going to lower my 360 about 5cm front and back. Any ideas how these wheels and tires will fit on when it will be lowered? Should I expect fender scrubbing or something like that. Seller is living in another town so I would like to have some information before going and putting them on.
http://www.willtheyfit.com/index.php?wi ... 20#content
According to this rim should poke out about 6,5 cm and I think is a lot
Re: wheels sizes
Yea you'll have issues with 16x9. If they don't stick out they'll hit the strut. Too wide me ghinks
Own:
86 & 89 360GLT
00 S80
02 Subaru GT30
Owned
86 & 89 360GLT
00 S80
02 Subaru GT30
Owned
Re: wheels sizes
Probably need some spacers and a bit of trimming on the body for clearance
Re: wheels sizes
Only 5.5j 0r 6j, and can't quite remember offset either haha but it's very low!
