Welded Wings?
Cloud
Welded Wings?
Post by Cloud »
Ok, so I've completely stripped the front of my 360 now, bonnet, lights, grille bars etc. When i came to remove the wings and I've noticed what looks like welds or filler on the lower half of the wings where they join the chasis at the front, under the headlight (should have taken a picture.) Are these welded standard? Is it just filler or something else? Any recommendations for getting them off without just ripping them off?
Trying to limit damage here lol. Oh, Sven...do you want your newspaper back from the wing? :D
B Volvo 360 GLT - 2.0i 52k
jarlidge
Post by jarlidge »
hi
its like a joint compound of some sort if you give them a good tap it will
split the joint and you can carry on removing the front wings.
jeff
Cloud
Post by Cloud »
ahhh Volvo300mania.com fast AND efficient. Cheers :D
Figgy
Post by Figgy »
I need too remove a passenger side wing/guard/fender panel, so now that I know that there's this stuff in the join....what do I use to replace it when putting the panel back on?
Post by bogbasic »
Hello, you could use a flexible roof sealant from local DIY, but if you don't remove the old sealant it will seal itself up quite well when you replace the wing, anyhow, and you could just put a bit of waxoyl on for luck - I think I did this. Cheers, bogbasic.
Post by bogbasic »
Here's the proper answer to your question:
http://www.frost.co.uk/item_Detail.asp? ... d%20(400g)
Figgy
Post by Figgy »
Bogbasic - Thanks for the speedy reply. I'm a total newbie to all this bodywork stuff and research everything on the net and pick peoples brains on every subject, before I attack anything.
Last week I needed to learn all about fibreglass, (to rebuild the sill under the hatch) so I spent a lot of time talking to a local bloke who a few years back built a whole fishing boat. The sill looks like it came straight out of the factory. so I'm very please with the results. :lol:
